S7 300 Encoder Counter
HarleyRay0
Nov 2011
Surrey
I am new here and a novice to programming, I want to connect an incremental encoder to a Siemens PLC CPU 313C-DP for the purpose of measuring the over travel on a conveyor belt after it is signalled to stop. I have set up a test program to run the belt forwards and backwards for a maximum of 200 stops.
Could someone tell me an easy way to log the counts for each of these stops and the simplest way to connect the encoder which has a pulse count of 3600? I am not expecting the count to be high as the drive motor is braked.
Encoder data sheet attached.
Hi HarleyRay0.
The PDF does not show exactly what each pin on the encoder does.
I think you have to connect GND (0v), Ub (24V from counter module), A (1st channel on counter module) and B (2nd channel on counter module).
I use the 1 COUNT module 6ES7138-4DA04-0AB0 for ET200S. There are several modes of operation (once-only, endless, periodic, speed, period, position feedback) so you should check the manual carefully, and choose the one that suits you best.
Thanks Jesper,
I was going to use the onboard counter of the 313C which uses a digital input card on the station, but the 6ES7138-4DA04-0AB0 may be a good alternative.
Hello guys, am trying to figure out what specs an encoder should have to correctly connect it to the auxiliary feedback on an AB Kinetix 5300...
975
Hello Every one I am trying to connect the encoder with siemen's 300 plc but dont know how to do it... Could some one send me the connection of...
2,218
I need to design a flying cutoff system with MP2300 - MECHATROLINK-II communication SGDV Servo drive SGMVV Servo How should I read the line...
2,564
Hi Everyone, I want to know how i write a program in S7 300 plc of absulate encoder profibus dp 32 bit.
2,536
Hi I want to read degree from absolute encoder 1024 binary by plc s7300. Please Describes the functionality of the absolute encoder 1024 binary...
4,394
