S7-300 I-Device config
cottagewood
Oct 2005
Kent
179
I have a 315-DP/PN and a 315-DP with a CP343 card and I'm trying to configure i-device. The step 7 5.5 help gives a step by step with screen shots, however, I've followed it and I don't have all the tabs that are shown in the help, specifically, I don't have the i-device tab and check box for i-device mode
I just have these 4 tabs for the interface
Does anyone have any ideas?
Honestly, I only use i-device if someone makes me. Much easier to use netpro to create a connection and use AG_Send / AG_Recv in my opinion.
But, i recreated what you described and i-device appears in both processors without an issue. What 343 card are you using?
A cp343-1 lean,
I hadn't even got as far as configuring that side, I stalled at configuring the i-device on the CPU315-dp/pn
If I use the 3.2 f/w from the h/w catalogue, I get the i-device tab, if I use the 2.6 f/w or below then I don't
I had more than 1 config open at the same time, I closed them all and open just the 315-pn/dp and I can see same, thanks every one for you help
Gee, I thought this was going to be easy but I'm still struggling with it.
I can't use i-device because the CP343-1 lean is not an io controller so I can't add the i-device i created on the CPU315/PN from the catalog.
So then I tried to use iso-on-tcp but netpro will only let me partner 2 CP343's and not a CP343 to a CPU315/PN
Anyone got any other ideas?
You can use put and get blocks on 315 pn/dp and read from / write to datablock areas to CPU with 343-1 lean.
I'm trying to setup two S7-319 CPUs to communicate over profinet (currently using Profibus) which are both in the same project. I watched a...
30
8,300
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
Good Morning!! I am trying to configure a siemens s7-300 cpu as an I-Device, to read the data on a GE RX3I PLC. Do you need to do some ladder...
3,342
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,484
Hi, Can some explain me what's the measining of this option inside hardware configuration. When should I want/need this option to be...
2,922
