s7-300 pc cable
please help
Guest
P
i need to find out what pc cable i should buy to talk to me PLC using my laptop and not by the PG, i know that the PG cable to the PLC can be used iether on the MPI or profibus plug, ofcousre profi is much faster, so is there a PC cable out there that can allow me to plug into both like the PG, and if so, what is the part number? thanks
COM/MPI or USB/MPI
Impossible. In PC COM port RS232, in PLC MPI/Profibus RS485. Need adapter COM/MPI or USB/MPI.
Try their USB adaptor part number 6ES7972-0CB20-0XA0.
I have been using one for about a month.
Talks MPI, Profibus, and as a bonus, PPI to the S7-200.
Doug
If you have a serial port, you can use the PC-Adapter or the TS-Adapter. For the TS-Adapter you will need the Teleservice Software.
Hey,
I'm using a MPI/RS232 adaptor for communications between
my portable and the PLC.
Hey Guys I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had...
2,053
  • Poll
I am beginner for PLC programming and I have cable s7 300 USB/MPI cable but unable to find drivers for that cable . Can any one help me to find...
3,093
I did a little bit of sercing here and on Siemens site for a communiication cable between an S7-300 CPU and PC's USB port. However there are...
2,151
Hello Everybody I´m looking for pinout for cable PC-Adapter to CPU I have bought in ebay only the PC-Adapter USB, now I need the cable for...
3,262
Hi All, Currently There is Panelview 300 Communicating with 1794 Flex Processor L34 on RS 232 Port (DH 485). The Flex Processor will be...
2,632
