S7 300 PLC and Indramat
arturnok
Apr 2012
barcelona
42
Hello Gentelmans,
There is a problem on the machine which uses s7 300 and Indramat servo controllers with Rextroth drives.
the Indramat controller:
PPC-R22.1N-T-NN-P2-NN-FW
the Indramat control section is:
CDB01.1C-SE-EN2-EN2-NNN-MA1-NN-S-NN-FW
As I see in the S7 program and as I understand, the s7 300 sends and recives data ( torque, speed, position) with the PPC via two DB- DB_RD_MUX_DATA32 and DB_WR_MUX_DATA32.
The DB's are ARRAY[0..15,1..25] of integer.
How can I find each direction of each parameter inside the arrays?
Is there all parameters on that table?
Does anyone know where I can find a list of all parameters with the description of each one?
On the Rexroth web I couldn't find a manual with all parameters for this module.
I'm not a servo guy :confused:(I'd like to be) and I'd like to ask You how some parameters which I've found in the program works:
Sinchronizme,
Idle mode,
Idle command enable
Idle speed,
Position mode
regards!
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
231
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
703
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,018
Hello, I have a bit of a situation, and I think I know the answer but this font of knowledge may prove something. I want to do the unthinkable...
2,189
hello guys, I'm trying to establish a connection between Indusoft 8.0 & simatic Plcsim but I keep getting the following error: error...
1,364
