S7-300 PLC CPU 314 - First Scan Bit
SelimHS
May 2018
Denmark
Hello Everyone!
As the title suggests, i would like to know how to program a "First Scan Bit" in S7-300 PLC CPU314. I made a sequence with 3 cylinders, which you can see in the file i attached. You will also notice in the file, that there's a first scan bit in the beginning. This is what i would normally do, if i was using a S7-1200. But sadly, there's no first scan bit in S7-300. You have to make it yourself.
I read something about OB100 (warm restart) which is the only thing you can use in S7-300 for a "First Scan Bit". The problem is, i'm confused to what should go inside the OB100. What should i put inside? :(
I should also mention, that i'm a beginner. So don't be too hard on me. :unsure:
You'll have to dig this a bit more, but the first OB being run when the PLC starts is OB100 (or similar, I think 100 is warm restart). Inside that OB, set a bit to 1.
At the end of OB1, reset the bit to zero.
Though I would think that OB1 has a first run bit, but don't quote me on that.
Same bit address on all instructions:
1st rung in OB1:
--|/|---------------------(S)--
last rung in OB1
--------------------------(R)--
Or this for the last rung in OB1:
---| |--------------------(R)--
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,709
Hi guys, looking for some advice from someone with some siemens hardware experience. Im a student considering buying a siemens plc to practice...
5,081
Dear Friends, I have a S7 300 (318-dp 2)P.L.C. I need to connect a touch panel TP 270 via wireless radio modem. My problem is the transmission...
4,116
Dear All, Currently i'm working with Endress Hauser flowmeter and AB PLC and try to integrate with 2 items. Flow meter spec using is Promass...
176
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
257
