S7 300 to 300 Ethernet Comms
YoungWint
Dec 2012
East Midlands
77
Hi All
I am looking at an application where I must read a data block from a number of package plants, on ethernet.
All plcs are S7-300 but are NOT within the same project.
At present I have my PLC and one of the other plcs available.
PLC1 Address 192.168.10.10 with CP343 192.168.20.10
PLC2 Address 192.168.10.20 with CP343 192.168.20.20
Anyone any idea how I can exchange data between the two?
My thought was Get/ Put instructions but am a bit lost in configuring the connection etc. etc.
Help please anyone.
It is quite simple.
When you setup the connection in NetPro, you select for the partner "unspecified", and set the connection details (IP, rack and slot) manually.
You have to manually mirror the setup in the two projects, as opposed to that NetPro do it automatically for a fully specified connection in an integrated project.
I have set up comms between an S7-1512SP-1 PN plc programmed with TIA v17 and an S7-314C programmed with Simatic S7 using GET and PUT blocks in...
572
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,041
I have a machine that has a Siemens PLC CPU 315-2 PN/DP. It has numerous remote units on profinet using a 192.168.0.x network range. Is it...
2,695
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,456
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,693
