S7-314 Ifm Rom
Prince
Jun 2002
284
I have a PLC with an S7-314 IFM CPU which I want to change its hardware configuration for communication purposes. As far as I try to change the Hardware cinfiguration the more I try the less it change. The CPU is equipped with ROM, I tried the "Copy Ram to ROM" in Step7 no error comes on but no change happens. the CPU is of the old types with 4 position selector and battery. I guessed may be there is a jumper or key on the CPU in order to protect the ROM. Can anybody help me ?
Sorry Jesper
The Help File says like this about this command:
" The function "Download to EPROM Memory Card on the CPU" deletes all the blocks on the CPU and on the memory card. All blocks in the block folder are then downloaded to the EPROM memory card on the CPU. The function is only possible if the CPU is in STOP mode and an online connection to the PLC is set up. "
"This menu command is used to write a user program to the memory card of a CPU.
Provided that the CPU has a slot for memory cards and supports this functionality (e.g. CPU416), and a memory card is inserted, the STEP 7 project can be downloaded to the card. The function can only be executed if the CPU is in STOP mode."
I will test it today on the CPU but does that mean that I must do this anytime that I make changes in the software ?
Can you tell me in brief what is different about this CPU? I was always thinking that this command saves a backup copy of the software project on MMC card. I am sure that you are aware that there is no MMC card on this CPU..
Use that funtion to store the program on the memory card. It is the same for MC and for MMC cards.
You should only use this function when you have finished your changes.
Before that you download to RAM, no matter if it is program blocks or HW changes.
But I see no Changes when I download the hardware Configuration changes in the normal way . It is just same as before when I try to Upload and new modules are not not working...
Hello to All, Recently I install a CP343-1 Lean to communicate with a CPU 314 IFM, however I can't go online when I'm connected via CP343-1 Lean...
1,675
hi everyone, I'm wondering if there is a way to connect a CPU314 IFM with only a MPI connection to a ET200S IM151? I'm used to do it with...
1,445
Hi, I am using a Siemens CPU 314IFM with DI4xDC24V | AI4/AO1x12Bit module. I want to know the position of a motor by coupling a 10k Ohm...
4,008
Hi, i'm having bit of a problem with my Siemens CPU 314 IFM, the integrated analog inputs. I wire my pt100 to the plc analog input according to...
6,339
Hi I have a cpu 314 IFM please introduce a link that have its manual.:banghead: Thanks Regards
1,457
