S7-315 DP and Profibus
Big_col
Dec 2005
Birmingham
Hi
I am having a go at profibus for the first timeo_O I am using a 315 cpu and an old S7-215 DP. I have configured the hardware in step 7 and when the cables are connected the lights go off on the 315 and turn green on the 215 to indicate the link is ok and data is being exchanged. In the 215 no of set is used so the data starts at VB0 to VB3. If VB0 - VB3 has FFh entered when the profibus is plugged in VB0 VB1 are reset to 0. In hardware config in step 7 the address view shows Q = 0, 1 and I = 2, 3 in address overview. When we try and read using SPC14 DP_READ we set the laddr to 2 I get an error 8093 No DP module from which you can read consistent data exists at the logical address specified in LADDR. I have been told by Siemens that I can read this information with out using SPC14
Have I missed something? any help would be much appreciated
Colin
hi there its my firest time working with profibus and i have already install gsd and networked profibus in step7 hw config and inserted base...
2,518
hallo i am having a problem the wago module and the cpu are connected with each other and the adresses are oke. but my tia portal keeps giving me...
4,689
Hi, Can you configure a Siemens CPU 315-2 PN/DP as a profibus slave? Is there an advantage to doing this versus using a DP-DP coupler? These...
2,375
HI All, I have just been asked to look at a new package Plant installation, where the supplier knows nothing about profibus. They have supplied...
3,466
Dear All, I'm using S7300 CPU315-PN/DP. As the manual states that its integrated RS485 port can function as MPI, DP Master and DP Slave. When I...
2,659
