S7-315 PLC (CP343) and an SCO Unix server
rmontema
Feb 2015
Dearborn
I am investigating the possibility of being able to communicate over Ethernet between an S7-315 PLC (CP343) and an SCO Unix server. The Unix server is already capable of Modbus TCP, but I have also found documentation on a SOFTNET-S7/UNIX product for communicating between these two systems. Before making any purchases or going further, I wanted to make sure that either or both of these communication methods were options for Ethernet communications between Unix and the S7. If they are both options, are there any documents, example code segments or other guides available that would be recommended for the Unix part of the implementation? Lastly, is it possible to use the Unix native sockets API for this communication rather than having to install additional software on to our servers? Are there other options that I may have overlooked?
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
73
Hi guys, This may be a dumb question, but here it is. Is it possible to use the ethernet auxiliary port of a G315 Redlion HMI to communicate...
2,983
Hello. I have serious problem. I was make some blower system. It was work well. But the problem happened 3 month later. Program is not erase...
5,152
Hello Experts I have a little problem in dealing with addresses. I am using a profibus absolute encoder Hengstler make. This encoder is spec2:64...
4,370
Dear friends, I need your help Is it possible to connect the PLC s7-315-2pn/dp to the computer network of the company? I want to use the...
1,938
