S7-317PN/DP comms to slave via UDP
Manglemender
Jul 2007
Lancashire
1,295
Hello,
I have a current project that involves adding a new load cell amplifier to an existing machine control system. Adding new analogue inputs to the existing I/O is a possibility but I noted that the device can communicate by UDP and wondered if there were any examples/advice out there.
I did find an example of two PLCs communication over UDP: https://support.industry.siemens.co...rface-of-an-s7-300-s7-400-cpu-?dti=0&lc=en-WW
CPU S7 317PN/DP programmed with Simatic Manager V5.5 and also has an MP270 HMI programmed with WinccFlexible2008.
The goal is to display measured tensions on the HMI.
Thanks in advance,
Nick
Is there any easy way to collect and send db- data from 317 cpu to desktop PC? 317 cpu has rj45- port, but cpu does not have internal web-...
2,638
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
390
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
91
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
67
