S7 400 and ethernet problem
ggchavhan
Nov 2006
pune
135
Hi
I am facing problem in configuration of my laptop ethernet port in PG/PC interface. It is show ind deactiveted
attachment.php
When I checked in Device Manager It was showing OK
attachment.php
Again in Simatic Configuration Console it is showing deactivated
attachment.php
Can any body tell what would be cause? and how to rectify this.
Please help
http://www.plctalk.net/qanda/attachment.php?attachmentid=12437&stc=1&d=1262782726
In the Device Manager, there is a device with a yellow question mark.
Something is messed up on your laptop, possibly some devices are conflicting with each other. You have to sort that out.
Before you can get to setting up the PG/PC Interface and Configuration Console, the ethernet card must work properly. And you must be able to ping the PLC from the PC.
Thanks JesperMP
I forget to inform that my laptop is having two OS boot option. I am indoubt whether it could be the problem?
I dont think so.
Simply put, resolve the problems in the device manager - then check that you can ping the PLC - then set the ethernet card in Set PG/PC Interface.
I cannot get a micrologix 1100 to communicate with a panelview 400 via ethernet.
6,134
We want connect our application to a Siemens S7 400 by using an OPC server. We tried the Kepware and the Applicom Direct-Link OPS servers that are...
10,901
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
126
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
843
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,186
