S7-400 CPU multicomputing K-Bus Speed
cagliostro
Feb 2007
vi
106
Hi all,
I've two CPU S7-400 place in main rack(UR1), these CPU work in multicomputing and I'm using the SFC73 I_PUT for data send.
I suppose that the data trasmission with I_PUT,comes by means of the K-Bus.
Can you confirm this?
And the speed of the K-Bus has the same speed setting in the MPI or not??
Thankx a lot in advance.
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,515
Hi All, I have a project that lets me control a Movimot drive via Profibus DP. A quick search on google learned me that a lot of information...
2,764
Dear Experts, We are currently in a project commissioning stage now of a Biomass Plant. The above mentioned CPU is used. 2 days ago, our load...
2,658
Hi, does anyone knows what is the problem on an S7-400 cpu in case all the leds are constantly on (not blinking, I think in this case it that...
7,258
I want to replace the exisitng CPU card of our S7 plc with spare card of similar type. Is it as simple as just remove old one after switching off...
1,544
