S7 Communication between 3 siemens 317-2pn/dp plc
IJK
Sep 2010
pune
67
Dear Experts
I have three Siemens master 317-2 PN/DP Plc
i want to do communication between them which is the best way to do it
i am using profinet
one way i know is using s7-connection and using fb14 send
fb15 receive
Please tell me if there is any other option.
If i am using S7 connection in netpro and ethernet hub for routing the ethernet cable to the plc
Where should i use cross ehternet cable and where shoud i use straight ethernet cable
With the blocks TSEND, TRECV, TCON, TDISCON, you do not setup the connection with Netpro.
Use the sample projects that I linked to.
Nobody uses hubs any longer. Using a switch, you dont have to worry about straight or crossed.
122
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
354
Hi there, I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol. I downloaded...
2,061
i have TWO PLCS ( ONE PLC M258 SCHENEIDER ) AND OTHER PLC IS ( SIEMENS S7-300 CPU314C-2DP ) SOFTWARE USED FOR SIEMENS IS TIA PORTAL V13 AND...
2,049
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,806
