S7 CP315-2<->SIMOREG DC/Profibus link
Laurent
Jul 2002
Montreal
110
Hi all,
I am not familiar with Profibus but have an excellent opportunity to improve my knowledge and know-how with this new project:
- A S7-300 PLC controls a tram system. The DC motor is driven by a SIMOREG DC power unit. The PLC and drive are both linked on Profibus-DP. Actually there is also an OP270B on the network, but we already found all the answers regarding this item.
The configuration includes: S7-300/CPU315-2DP <--> SIMOREG DC with CBP2 Profibus board. The drive has a 16 words PZD area. The HW Config manager allows us to select PPO 4 as a communication method, meaning 6 words in PZD area. The available programming tools are Step7 5.2 (5.3 upgrade in prospect) and DriveMon 5.3 (Drive ES to be quickly implemented).
I would appreciate your input and programming tips on three points:
- In that case, should we use SFC14 and SFC15 from the PLC in order to read/write the drive's PZD area?
- If yes, does this mean that we have to "scan" the PZD area by blocks until we access the 16 data?
- Can we access ("call") any useful data in the drive by the Profibus link OR is there a built-in limitation to 16 data to/from the drive?
Thank you in advance for your help and suggestions,
Laurent
Expand your sfc14/15 to 32 bytes or 16 words. Then go in to the hardware config- select NO DEFAULT- under type select -
-Actual value then length 16 words
-Setpoint then length 16 words
I typically make my I/O the same ie.. 256 actual and 256 setpoint.
As long as you point to the correct address in SFC14 and 15- it doesnt matter.
This will allow 16 words of write data and 16 words of read data.
Dear all. In New Cp315-2DP have MMC, but It does't have battery. I don't know why don't need to use battery. MMC is load memmory, but if CPU is...
3,361
HI: IM NEW HERE, CAN SOMEBODY TELL ME WHERE I CAN GET OLD SPARE PARTS FOR MY YASKAWA PLC CP315. RAM, CP AND IF CARDS. I DONT HAVE SPARE PARTS AND...
2,047
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
199
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
97
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
116
