S7 date and time
guest
Guest
G
Can anyone tell me how to display the actual date and time if you use a DT in a data block. I know it will not show you in the data view if you are online because it is 8 bytes.
Guest
You will have to split the 8 bytes up into single bytes, then the info is as follows:
1st byte = Year
2nd byte = month
3rd byte = day
4th byte = hour
5th byte = minutes
6th byte = seconds
7th byte = milliseconds
8th byte = milliseconds (4 MSB's) and day of the week (4 LSB's)
The day of the week starts at sunday, so sunday = 1, monday = 2 and so on until saturday = 7.
These bytes are in HEX, so you will have to convert them to INT in the DB, just declare the TYPE as INT.
Paul
Just one minor correction: The bytes will be in BCD format, so you will have to use the BTI instruction to convert them to integers.
Another problem with displaying them as an INT in a DB is that you can't view a byte as an INT. It is always in HEX view. So, when I use the Date_Time function, I always use a local variable, convert the bytes inside my function, and then pass the converted variables (day, month, etc) to a struct in my DB.
Thank you for putting me right on that! šŸ™ƒ
I was writing from memory, the ol' grey matter ain't as good as it used to be! banghead
Paul
Hi Paul,
What are you doing up at this hour? I would have thought that you would be at the pub getting ready for my up-coming visit... I got the job w/ the Biodigester Co...on my way down to get my Passport renewed right now!!!!
David beerchug
David_Emmerich said:
Hi Paul,
Hour? It is early evening on this side of the pond, I haven't long been in from work.
]Originally posted by David_Emmerich
Weekend drinker only me! I don't believe in drinking during the week especially when I have work the next day!
David, you will have to PM or email me when you are coming over.
Paul
P.S to Guest, my appolgies for this thread turning into a personal conversation between myself and David.
Can you please show how to set up a Vat table or DB to display the actual values.
Thank You
Hello Everyone, I want to upgrade the firmware of Powerflex 40 from 5.001 to 6.002 can anyone tell me how can I do that?
66
125
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
310
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
134
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
121
