S7 Distributed Safety Program Fault
winklerlars
Supporting Member
Dec 2008
Brisbane
I have started a new safety program Function Block with an instance safety data block. I can add FB217 (F_SFDOOR)to the STAT section of the safety function block but not FB215 (F_ESTOP_1)! Error says Environment\Interface\STAT\EStops. The data type is not permitted here.
I have had this problem before but not sure how I fixed the issue. Help would be greatly appreciated.
S7 Professional V5.5
S7 Distributed Safety Programming V5.4 SP5
S7 F Configuration Pack V5.5 SP8
:confused:
Hello,
I have the same problem. Have You solved it?
In one project I can define multiple instance call of safety library block, in other one it's not possible.
I'm using:
Step7 V5.5 SP2
S7 Distributed Safety V5.4 SP4
S7 F ConfigurationPack V5.5 SP9 Upd1
After few hour struggle I have solved the problem. In "S7 Distributed Safety - Configuring and Programming" You can read that before using some safety block from library You have to have F_TOF block under FB186 from the same library in Your S7 Program
Is there a manual or guide that details the acceptance test procedure? Customer requires System Acceptance Test on their automation cell with...
3,659
Hello, I'm programming my first S7 DS program, with a little help of the "S7 Distributed Safety Getting Started". I have a 317F-2PN/DP with a...
21
8,269
Hi everybody We have been having repeating emergency stops on our crane due to passivation of the F-module(PROFI safe V2, safety-related)...
3,576
Alarm Server Connection Status I am trying to tie a color animation to a rectangle that changes color when connected or disconnected from the...
524
Hello, I am trying to make a copy of a FactoryTalk SE Network Distributed application. I want to make modification but do not want to work on...
1,168
