S7 Ethernet programming query
Hugh
Oct 2005
Milton Keynes
I'm a complete newcomer to Siemens PLCs. I'm trying to get STEP7 (version 5.1) to talk to an S7-300 with a 343 ethernet card in it. I can ping the ethernet card but I get no ethernet comms option in the STEP7 set PG/PC interface dialog.
I've searched this site and others but not found a definitive answer. My best guess from my research is that I need a later version of STEP5 or I need another piece of software (Softnet) to be able to program the S7 from my laptop.
Any guidance will be greatfully received!
Hugh
When you are in the Set PG/PC Interface menu, there should be a "Add Interfaces" selection. You should see your 10/100 Ethernet card in your computer there?
Thanks for the reply.
The only options I see in the Set PG/PC interface are Profibus/MPI connections eg
CP5511
CP5611
PC Adaptor
Hugh
I believe you are right about the software version. You may need to upgrade to v5.2 Step 7. I would need someone to confirm this however...
I think you need to have SIMATIC NET installed on your PC
This is a add on to S7 V5.1 and V5.2
However, I believe that is included in version 5.3
Ian
Programming via Ethernet came in v5.2.
Your options are:
1. Upgrade STEP7.
2. or Install Simatic Softnet Ethernet
3. or Install Simatic Softnet Ethernet LEAN.
Hugh
I have a question for you.....
Has the S7 300 previously had the configuration/program downloaded to it via MPI?
If I remember correctly, you can download the program and configuration to a 'virgin' PLC via ethernet using the MAC address of the CP343, but I believe it is a pain in the butt to do.
I am sure this has been discussed on this forum previously, I expect S7Guy was involved. Perhaps a search for "MAC address" would turn up the result.
Paul
No no. It is easy.
There is an "Assign Ethernet Address" utility in STEP7. With that you can easily assign the IP address by means of the MAC address that is printed on the module.
From then on it is smooth sailing.
JesperMP said:
No no. It is easy.
I'll take your word for that Jesper.
This is also something that I haven't tried out, I haven't had the need to as I only use Field PG's for programming, MPI and DP built in.
Paul
Hi I’m having issues figuring out how to connect a Schneider ATV930 to Control Logix PLC. Can’t figure out the Connection Parameters, I used the...
1,199
1,007
OK, I've come full circle on my telemetry. Pipe dreams of 100mb 23ghz links to each remote station has been beaten down to 9600 baud routable...
2,818
Hello, is it possible to program (and debug) a DVP series PLC via Ethernet with the DVPEN01-SL Ethernet module? Like I do with the serial...
1,172
Hello, Is it possible to use this: http://www.moxa.com/product/NPort_IA5000A_Series.htm to program a S7-300 PLC (MPI or PROFIBUS).
1,926
