S7 fm350-1
jac
Aug 2009
Ontario
126
I want to use 2 FM350-1’s to count two quadrature encoders and use the same prox to gate them to store counts. Since the FM350-1 is a single channel is there a way of knowing we have the up to date data from both cards?
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,917
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,743
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,150
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,753
Dear All, Hw config. are 317-dp cpu with FM350-2 counter modle. Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)...
1,853
