S7 - Java Comms
Chonwell
Jul 2005
Viña del mar
Hi everyone,
I was working with Mitsubishi's FX-1N series. We developed a Java software that sent and recived data from that PLC using RS485. Right now we are thinking on migrating to the Siemens S7 family. My problem is that I read the S7-200 documentation and find out that the PLC could comunicate to their software (Step 7 Micro/Win), but it doesn't say anything about the protocol it uses. It says Profibus but I really don't know if we are gonna be able to comunicate to our software in Java, or if we can run profibus in Java. Any comment suits me...
There a few options possible.
The S7-200 support on its onboard ports following protocols:
- PPI(Master/Slave)
- MPI(Slave)
- Freeport (simple ASCII/Binary communication for user own protocols)
PPI and MPI are subsets of Profibus.
There is a PPI specification you can buy (expensive).
For Profibus spec. you must be a member of that org.
Solutions:
1. Use the CPU in freeport mode and add your (existing) own simple protocol(or use modbus).
Other S7-200 panels couldn`t be used on the same port, you need a CPU with 2 ports or EM277 extension module.
2. Write an Java OPC client and use the S7-200 OPC-Server (called PC-Access)
You could use Panels at same port. Server runs on Windows only.
3. Implement PPI protocol -> heavy
4. Take a ethernet extension (CP 243-1-IT) module with built in Java-Webserver and FTP-Server.
Does anyone know what version of java is needed to view the webpages of EthernetIP Safety I/O blocks from Rockwell; I can't find any mention of...
1,594
motion view application for our kineticx 300 does not launch automatically.java latest version 8only installed in our VM ware system . I...
2,590
Hi everyone, I'm looking to get into Ignition, so I downloaded the latest and greatest installer from their site. (v7.9.10) When trying to...
3,202
For those using Ignition, this is a must read from Inductive Automation regarding Oracles decision to require commercial licensing for java in...
2,073
Has anyone had any luck getting the JAVA interface for the Kinetix300 drives working with windows 10?
3,096
