Hi guys,
Disappeared few weeks for writing code, I'm back with a problem.
There is a repeating work for different group of signals, so I decide to go with FC (I don't need IDB), and the signals in different DB but as the same UDT. so it's like
DB1.G1.f1
DB1.G1.f2
DB1.G1.f5
DB1.G5.f1
DB1.G5.f5
DB10.G5.f1
DB10.G5.f5
G is the name of UDT, and f is the elements of the UDT (Boolean).
Because it is too much parameters, I want to use a pointer to the start address, so within the FC I can add shift and get the right element. So the input is an "any" data type which is a pointer should including the DB name and the Address info. and inside the FC it's like
[AR1,p#0.0] for elements 1
[AR1,p#0.1] for elements 2
[AR1,p#0.2] for elements 3
[AR1,p#0.3] for elements 4
[AR1,p#0.4] for elements 5
When it's running, it seems the pointer pass some other values and the logic doesn't work. I simplyfied the logic to test it like
A [AR1,p#0.0]
= DB100.DBX0.0
A [AR1,p#0.1]
= DB100.DBX0.1
A [AR1,p#0.5]
= DB100.DBX0.5
Then I turned the bits on outside of the FC,But all the bits in DB100.DBB0 is always off.
Did i do wrong with the indirect addressing or something else?
Thanks for help.
DB1.G1.f1
DB1.G1.f2
DB1.G1.f5
DB1.G5.f1
DB1.G5.f5
DB10.G5.f1
DB10.G5.f5
A [AR1,p#0.0]
= DB100.DBX0.0
A [AR1,p#0.1]
= DB100.DBX0.1
A [AR1,p#0.5]
= DB100.DBX0.5
Thanks for help.
