S7 SDB 2002 Error
sohwel
Aug 2005
Kuala Lumpur
53
Hello,
I have a problem with downloading to PLC with my S7 V5.3+SP3. The screenshot is the error message I got when downloading. anyone have this problem before?
Regards
I had the same problem with downloading SDB a few times. When working with distributed IO the reason is interpretation of GSD file by Step7, it newer happend with older versions of Step7. Let us know more about your HW Config, so then I think someone could help you.
Hi guys
Ive been a long time reader, with not much to say yet :)
Great forum.
Was wondering if anybody has a answer to this question? Im having the exact same problem.
I have a 400 Station with distributed IO.
When I do the HW config, it allows me to download it once. I can go online and everything. As soon as I change the HW config and/or try to download anything again, it downloads about 75%, and comes up with the same error message as in the first post. Then I also cant download any blocks from my program.
I then have to take my batteries out, dip the power, and then I can download the hardware again, but only once.
When Ive downloaded the hardware the first time, I can download all my blocks from my program, and they download fine all the time if i DONT load system data. If i load system data then it also bricks itself and I have to erase the whole PLC again.
I am past frustrated with this! hehe
Does anybody by any chance maybe have some information that I could try? It would really be much appreciated
Many thanks
Couple of things to try if you've run out of options......
Do a File > Save As and check the reorganisation(slow) box.
Open your hardware config, press CTRL-ALT-F11 then save and compile.
Reviving thread because I couldn't find an answer:
What does pressing "CTRL-ALT-F11" in the Step 7 hardware config do exactly?
Install SP4 for V5.5 if you don't have it.
From HW Configuration, download and install HW Updates.
Make sure you have the correct firmware version of your CPU selected from the hardware catalog.
Try an overall reset (if this is a new CPU you are trying to install and download!) and download the HW config again.
Hi I uploaded a project from my simens S7 PLC to my computer.After uploading when i tried to compare the blocks online/offline , it gives me...
1,544
I am using the RSview32 VBA to write to a Access table. Works great for me, however no one else can open it on the network. Here is the code for...
1,328
Hi, S7: CPU400 and 300's in project (I am a novice) I've made no changes to the project. SDB matches online. everything is hunky...
4,468
I came across the following coding method which appears to use SFC20 to copy from SDB200 (the SDB used for configured connections) by specifying...
3,115
Hi, I had a project with 6 stations, some already had connections to each other.. I needed to add another station and make an s7 conection to...
2,916
