S7 STL Dword to Byte
rikcando
Apr 2012
Ontario
128
I have been beating myself up for the last couple of hours trying to figure this out. It seems so simple but I really am missing something.
I have a function that I am sending a MD DWord and I need to return just am MB Byte. The value will never be more than +/-500 in the DWord. I have a return bit for negative and a return bit for overflow.
In: DWord value +/- 500
Out: Byte value 0-255, Negative bit, Overflow bit.
Attached is a picture of the latst attempt. I have tried ABS, MOD, AD, (SQR:SQRT), all with the same result.
Assuming I input -38 I would expect 38 in the byte, the negative bit on, the overflow off. I get the negative bit but the byte holds 218.
Please help me to undestand this. Thanks.
I have it, and it was something really simple.
If it is negative just multiply by -1 before the transfer. Jump past it if not.
Code:
  L 0
  L     #XOffset
      ==I                               //check if 0, add 1
      JCN   _00X
      +     1
_00X: NOP   0
      <I
      JC    _Xfr
      L     -1
      *I
_Xfr: T     #bXoffset
At that point yes.
I cannot handle a 0 on the recieving end of the communications. A 1 is minute and will not effect results. A zero will be assumed as no communications. But nice catch.
For reference, here is how you can use the abs instruction (which only works on floating point numbers)
Thank you.
I just took the time to look up the DTR and RND instructions in the help files. I am glad it had a description of the IEEE-FP format because I was really wondering how -100 tuns into -1027080192.
Could this be why the SQR then SQRT did not work as expected. I was not using the correct numerical format?
i am new to simatic manager and i am trying to figure what this part do in the code : A I 5.6 = DB50.DBX 4.6...
144
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
220
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
355
First off thank you in advance. Second I am very new to STL. I am trying to build a counter that has one count up and 23 count down options. Am...
396
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
705
