S7-tool/ProTool with RS-Linx services
seppoalanen
Jan 2003
Finland
1,132
S7-tool/ProTool with RS-Linx services:
My 'empiric' test have given following results. When RS-Linx services running in PC, the Step7 v.5.3 and ProTool 6.0 sp2 don't work perfectly.
-'Edit symbol' from ladder tool don't work.
- In ProTool, locations of text don't work in screens.
Simatic Step7 and PC-RAM:
Step7 v.5.3/ProTool Project needs 1GBytes of RAM-memory even PageFile is how large ever or some process works very very slowly when plenty of Simatic-applications are open.
With 256MB ProTool downloading don't work, a lot of other errors appear.
With 512MB cracks even os. when 'everything' are open, among others HW-Config download.
Seppo
I'm running Step7 and ProTool Pro V6 on the same PC with 512 MB memory. I don't have any major speed problems under normal circumstances, but have decided to upgrade to 1GB because of continual MS error messages in ProTool Run-Time - although everything still seems to work, but it's a bit of a pain in the neck.
Open up an S7-Graph program and go online to observe, and the whole lot crashes in a couple of minutes.
Windows bonkhead
Do you still have problems when RSLinx is not running as a service?
I also use Step7 V5.3 and ProTool/Pro V6 + SP2, but I don't run RSLinx as a service. I don't have the problems you describe. Use Lauch Control Panel to disable services.
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,528
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,403
Asking for a friend who has a Protool v1.0 project. He needs to migrate it, and for that he needs to first migrate to v2.51 which he does not...
1,165
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,455
HI All I am looking for a way to convert a protool project to win cc I have win cc 2008 SP3 and also newer but from reading I need 2008 SP2 or...
2,749
