S7 vat table
goxx
Jan 2005
84
we are having ghost stops on our machine which could be caused by several faults. the faults reset themselves during the scan, so eyeballing the input isn't possible, especially with several remote modules aboard. is there anyway to set the bits up in the vat table and have the vat table let me know which one made the transition? thanks.
No, I'm afraid not. The best you can do is to code some "traps" in the places where the faults might occur (by the way, these "ghost" faults look like sloppy programming to me, and that should be looked at when you have time). All you need to do is find some free bits (preferably Mx.x so you don't worry about which DB is open), and plug them in as necessary.
If you don't have the source code or the blocks are protected, then your options are more limited. If it is a real world input that is flickering, then you could hook it to a second controller and monitor it I suppose. Or, you could connect the inputs one by one to an oscope and look for abnormalies.
thanks S7GUY
that's what i was afraid of, thanks for your reply. i have been latching them in using free bits, narrowing the problem down, maybe 8 bits at a time. i can get it pinpointed after bout 5 faults. just time consuming, was hoping the vat table could do the work for me. and i do agree with you, it is sloppy programming, i plan to put permanent latches in there seeing how that is my only alternative. thanks again.
hi guys, please i need to know how edit a table for monitoring a variables in my online project like a VAT in Siemens Step7. tanks Diego
2,519
Is there a way in RSLogix5000 to setup a table to monitor some tags? I am looking something like the VAT tables in Step7 or Animation tables in...
2,575
Hello guys! I have a VAT table which consists of 1024 rows (maximum) of data, this is all data that I have to upload from the plc to my computer...
6,368
I am trying to build an FB as a wrapper for a timer... as any of you know me I am jumping into siemens newly/lately. It is not behaving the way I...
51
17,907
Dear ALL, i have a DB that has a variable as DBD for exampl DB209.DBD40. that double word contain a number that no other FB or FC write to it. i...
1,837
