inayatswatpk
Dear Members,
I have to establish a connection b/w S7300 PLC with CP 343-1 lean and S7400H system with two CPUs and two Ethernet CPs CP443-1. The physical connection is Ethernet. I need some advice on what type of connection should i use in netpro and what Function Blocks i shall use to achieve this. Also i want to have a redundant connection b/w the two stations. I know it is not possible with S7300 but i know there are some programming options when you make two independent connections in S7300 one with each S7400 CP. I need a sample program if any of you have implemented this logic. Also i want to know if i can use communication by MAC addresses with CP 343-1 LEAN. As i have found that CP343-1 LEAN doesnot support ISO and thus may not support MAC address communication. Any advice from senior members and experts will b very much appreciated. Thanx.
Inayat Khan
Inayat Khan
