S7314 H/W Compilation error
johnmck66
Aug 2007
Manchester
96
I have a guy on site trying to compile a hardware config.
Its coming back with
Download [-,0,2,-] number of fixed connections: value 9 is not within the range [0]
Anyone come across this one before ...please.
I'll take a guess that the problem is too many configured connections in NetPro.
I just ran a test, and I managed to setup 13 connections in NetPro, but it compiled OK despite that max 12 connections are supported by a 314 (*).
So I am taking another guess that the number of connections are checked upon download only.
*: This is a deficiency in STEP7 if you ask me. There is no check of if the project can run on the target CPU before you attempt a download. There is also no check of i/o image, number of timers etc.
Hi, One our customer is asking if we can put a second operation panel to their "old" machine. "Old machine" consist S7314 CPU and OP7 connected...
3,649
I was wondering if somebody could give me ahead start on how i would send a bit from one plc to another.For example, when an input is on in a...
1,846
does anyone have any logic that they could email me to control a 440 drive from a 314 plc. basic, run, stop,fwd, reverse.again this is the first...
2,478
Hello, I'm trying to compile an older panelbuilder32 application so I can throw it on a panelview. I'm getting a bunch of the same error 'Error...
1,780
Hi Friends I just started with Allen Bradley's micro logix starter lite/SLC500 emulator. I was following an info/instruction on how to start...
12,906
