s7315-2dp CONT_C Block for PID Control
sirhiss2
Oct 2003
109
I have OB35 created. I inserted Cont_c in rung, addressing it to DB1.
Info:
My A/I address starts at 448 and ends at 463. I set channel 1 to 2dmu current (2 wire transmitter 4-20 mA)and deactivated the other 3 channels.
My A/O address starts at 464 and ends at 471. I set channel 1 to I (current) 4-20 mA and deactivated other 3 channels.
Questions:
#1 - Where do I enter my analog Input and output addresses?
Is it in DB1 under address? PV_PER indicates 14.0 (under address) set for word W#16#0.
LMN_PER indicates 76.0 (under address) set for word W#16#0.
#2 - If I were to create other DB's, would I use these addresses In DB1 for A/I and A/O addresses?
#3 - Can I use OB1 to do the scaling and can I call A/I info or DB info after it has been scaled from DB1?
Guys, I'm new to your site, so hi to all. I have a situation where occasionally I want a a number of Siemens S7-300 PLCs to crash or stop. I...
3,912
Hello Guys, I am using a S7315-2DP CPU, P.No 315-2AG10-0AB0 V2.0 (Integrated DP port) for controlling 4 Danfoss Inverter (VLT2800...
2,469
Hi all Does anyone know the part number for the battery module on the S7315 2DP. I have looked through the manuals and searched the net but had no...
2,902
Hi I am trying to interface operating panel(TP 170B and spftware is WinCC flexible 2004 standard) Siemens plc S7 315-2DP. In operating panel i...
1,756
Hello everyone.. I'm new member so nice to meet you! I have both a theoretical and a practical question .. At work we have a PLC...
24
5,838
