Safety circuits
spartacus06
Jul 2017
MI
43
Hello All,
I am in the process of integrating several separate ESTOP safety relay circuits. My plan was to wire each individual PB back to a main ESTOP relay. From there, I will send back a dual output signal to each system. Combination of spare N.O. contacts and Expansion Relay outputs. I would like to know if I can use the output signals (ie AB 440R 14 & 24 terminals) to tie-back to the individual ESTOP input terminals (ie AB 440R S12 & S22 terminals) for each system that is already in place. The system will be setup with redundancy for the inputs & outputs. Also, I am estimating that I will need to enable 5 different systems. Can I add multiple relays to each output or have to add an expansion relay?
Please let me know your thoughts.
Sounds OK in principle.
I don't completely understand your question. You need to consider the load current and utilization category, whether or not you need isolation between the loads, and how the diagnostic coverage is provided for e.g. non-opening of the relay. Or are you asking the difference between safety expansion relay vs normal non-safety relay?
Hello, Should ESTOP circuits de-energise the control circuit or the power circuit to a motor? I want to put multiple ESTOPs to a safety relay...
1,966
Hello Im an Controls Engineer that has been asked to supervise some projects. Im new into this and suddenly everybody is talking about risk...
1,458
Guys, I am curious if this is okay. We currently use the Relay output of the PF525 (set 76 to 29 [SAFE-OFF]). We then daisy chain all these...
18
16,250
I am sure that everyone have heard about the big Toyota mass recalls of recent model cars and light trucks. I have participated in other forums...
31
13,250
Looking to learn more on Category 4 Safety circuits. Anyone have a good link? Thanks
4,300
