Saia pcd4
georgeawny
Sep 2011
Helwan, Cairo
Good morning.
I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any malfunction happen to the CPU.
So, could you support me with information about the software I should use and the connection cable to PC?!
Hi georgeawny
You will need a cable Pcd8.K111. Google will give you the configuration.
You need PG5.1.4.300 +patch 15 + possibly a driver update.
You will find it here: https://www.sbc-support.com/en/product-index/archive/pg5-controls-suite/pg5-14/pg5-14-suite/
This version is obsolete, and the latest version for Pcd4. It runs on Win2k/XP/Win7.
You should be able to download /install it free for 90days. Later versions (PG5.2.xxx will not support Pcd4!)
Bardes
Thanks all for your support. :site:
I uploaded the file successfully (xxxx.upl), but how can i open it to see the code and how can i re-download it to another CPU?!!! :confused:
Appreciate your support a lot. Thanks.
The xxxx.upl is a compiled file that you can download directly. You may fx use a command from the debugger: F(ile) and then L(oad) to download the file.
The file contains no symbol names or program text, but can be disassembeled to .src code or text. You will find it under Tools.
The readabillity may depend on how it was programmed.
Bardes
Hello
Can anybody help me related to the above topic?!
How can i re-download the uploaded file (x.upl) to PCD4.M11?!
I need steps to do it in PG5 1.4
Your help is really appreciated
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,089
Gentlemen, I am looking for some parts for a SAIA PCD4 system. If anyone has any of these parts for sale (new or used) please leave me a PM...
6,042
Hi with lot of negotiation with our plc contractor, they handed us source files which are in .src and .pcd file. They also handed over some dos...
2,887
Hy Everybody! I'm trying to use EXOR TextTerminal with Saia PCD4 PLC. I use Deisigner 6. Must in PLC set communications parameter, or what's is...
3,079
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
167
