SAIA software
Twister_vdb
Dec 2003
I got a second hand Saia PLC type PCD1.M120 which should still work properly. I also got the original software titled "PG5 1.0" but without code.
Can somebody help me in this matter please, so I can use this PLC?
Thanks already,
Vincent
Hi Vincent
Here are some links:
PCD1 manual: http://www.sbc-support.ch/pcd1/mxxx/m1x0/pcd1m1x0.htm
Drawing of the download cable should also be in that manual.
Be aware that the PCD1.M120 doesn't have battery, but instead a super-cap. with about 7+ days data protection!
PG5 software support page (documentation and software):
http://www.sbc-support.ch/pcd8/pxxx/pcd8p5.htm
Pg5 v1.0 is obsolete, but on the support-page there is a full version of PG5 v1.2.130, running for 90 days.
I don't think your key-disk will work on this demo-version.
Note also that your key-disk include the name of the original owner...
You could also contact this adress:
Saia-Burgess Benelux
Mechelsesteenweg 277
B-1800 Vilvoorde
Belgium
Phone: +32 (0)2 456 06 20
Fax: +32 (0)2 460 50 44
BTW: Within an hour you is able to edit your original post
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
171
I've got a Saia PLC and using PG5 software. Now I want to connect to the PLC but I only received the .PDC and .5hw files. Is there a way to get...
2,015
Hi All, I'm searching for a way to work with the SAIA PG5 Demo past the expiration date of the demo. Recently I installed the demo and created a...
9,724
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,090
Hi there. I am trying to read time of day from a Modbus register in SAIA PCD3 however I have limited data about the point. It should be read as...
2,400
