SC22-3E Ethernet Problem
Bbarnett
Jul 2013
United States
77
I have an SC22-3E safety controller from Banner. I can't connect it to my network... Ethernet/IP.
IP Address: 192.168.1.6
Subnet Mask: 255.255.255.0
Default Gateway not configured.
Everything else on the network replies from a ping command.
I am connecting it to the network with a straight through ethernet cable. Is this the problem? It says in the manual:
The SC22-3E supports use of either standard or crossover-style cables
I was assuming 'standard' means 'straight through' but this may not be the case?
Bbarnett,
I am using the several of the same safety controller over ethernet.
Are they connected to a managed switch which is divided in two or more sub-networks (Not sure what the correct term to call it, all devices are in the same IP range but they can be forbidden to talk to other devices on the same network?
I have a managed switch where ports 1-16 are assigned to certain devices and 17-24 are assigned to others. If you laptop is connected in any of ports 1-16, you will not be able to ping 17-24.
Thanks for the reply, Jothiswarup. I have everything connected to a Moxa 508a switch. The switch's settings are such that any IP address is allowed.
Connecting directly from laptop to safety controller, I still can't ping it.
The Banner SC22-3 safety controller is a product that I've become quite familiar with over the past few weeks--I'm using one on my latest machine...
11,893
179
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
97
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
315
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
470
