SCADA Citect - Creating Genie
Tim.K
Jan 2020
Kamloops
Hi all,
I am very new to Citect, and trying to make my own Genie.
What I have done:
Create my object and assign function -> On when " %Run_Status% = 1.
Made my own equipment type.
Under items, tag names are all -> {equipment.TAGPREFIX}_Run_Status or etc
Linked a Genie into Equipment type.
Under Genie Properties, Run_Status = {equipment.TAGPREFIX}_Run_Status
When I paste Genie on the graphic builder, it gives me an error "Operand Expected."
In Graphic Builder, {equipment.TAGPREFIX} does not transfer into my actual prefix, it stays how it is.
Anyone knows how to transfer {equipment.TAGPREFIX} into actual prefix?
Thanks!
Not 100% sure but "Run_Status = {equipment.TAGPREFIX}_Run_Status" probably needs something like:
Run_Status = {equipment.TAGPREFIX} + "_Run_Status"
This is the format I used for a genie
mnpr%nwp%_diff_volts
%nwp% is number of the unit i pasting on the screen
When you paste the genie you will be prompted to fill
in a value.
final is = mnpr123_diff_volts
I have no idea what you are talking about, but when I saw the word "genie", I thought of that genie game, where the guy can guess any celebrity, athlete, or character you are thinking of.
Hi everyone, I am trying to create a medium sized Citect SCADA project utilising a Control Logix PLC. I want to adopt good practice from the...
2,369
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
104
130
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
356
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
464
