SCADA Tag names
Jaybird929
Jan 2016
Massachusetts
Hello,
We use GE iFix SCADA systems where I work for our GMP data collection of GMP freezers, incubators and refrigerators. For our temperature and CO2/RH we use a tagname such as FRZ1952_HT for temperature without a second input of RH or CO2. With a second input we have it as INC1952_HT1 and INC1952_HT2 for Temp and Co2/RH.
What should be the standard for tagname post scripts. The INC1952 is the actual equipment name, just not sure why they decided on the HT1 and HT2 post script.
I usually work with ISA S5.1-1984.You can find a brief introduction and examples here.
Most of my customers use the same ISA-coded tagnames through all the documentation, even inside PLC, HMI & SCADA logic. I like that way because it's easy to create & assign new names.
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
115
Hey, I'm trying to do the following, I have some experience with Citect but can't seem to figure this out. I/O Tag: BoxPos1_ProdNum (Data Type...
607
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,183
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,987
who can teach me how to edit tag adam 4017+ in citect scada? real external I/O
885
