Scale Function on MicroLogix 1200
shayne
Dec 2002
Just a quick question regarding the SCALE function available on RS500. I was trained on RS5 and was taught to use block transfers for analog conversions. Apparently these are not used in RS500, so here is my question: is the SCALE function used for analog conversions exclusively or is there another function that was added to replace the block transfers?
You used Block Transfers for scaling, huh? While you certainly COULD do it that way, your data was limited to -9999 to +9999 (four digit signed BCD) if I remember correctly.
Most people use the BTR to get a raw 0-4095, and then an FAL to convert it to engineering units.
The SLC (and micrologix) work differently - the raw analog (3277-16383 instead of 0-4095, depending on the signal) come directly into the I/O image table, so no BTW/BTR is needed.
The scale functions (SCL and SCP) can be used anywhere you need to convert from one linear scale to another (you could use them to convert ºF to ºC, for example), but are typically used to convert the raw analog inputs to engineering units.
While working on a new program with CCW ver 12, I am trying to scale an analog temp sensor (4-20 loop input) with EU to Real. All of the...
1,848
Hi, First time using scale function and not quite sure whether it is right or wrong. Please advise and below is what I have 1. Using Allen...
18
6,059
Hey all, Trying to get my head around the Scale function using CCW and a Micro820 processor. I am trying to scale a raw AI into a view able 0-100...
1,905
Hi, I'm using thermistor as my analog input. Thermister is a negative coefficient and AB scaling seem to only accept positive(this could also be...
3,499
Hey all, Im having an issue writing a program of Siemens TIA Portal 11 for the S7. When using the SCALE function block, it doesnt want to...
4,704
