Scaling in Schneider's SCADAPack 330E Modbus
ajmist
Jun 2014
Tucson
SCADAPack 330E has various ports and protocols available. I'm using Modbus RTU over serial. I/O Devices (scan packets) configured for this have Gain and Offset parameters available for scaling.
In my case despite polling data in floating point, I need to scale the values (metric to imperial units).
Has anyone had this working? The logical values vs the physical values do not change - ie have an effective Gain of 1 and Offset of 0 regardless of what I enter.
Testing more, it doesn't matter if the registers are float or integer. Integer ones are not scaled either.
I'm using SCADAPack Workbench as the programming and debugging tool.
There is a parameter that enables master scaling. This must be on for any scaling to occur. I don't think you can scale floating point but I could be wrong
There is no parameter that enables master scaling.
Schneider Technical Support confirmed that the device scaling feature is currently unsupported. It does say that in the help file, but takes a bit of finding. "Unsupported Features"
Dear All, I need to know if I have a pressure analog signal input(4-20mA) and need to get an output analog signal (0-10VDC) to a pump controlled...
1,906
Hello! I am new at PLC programming. I am using TM221CE16R PLC with TM3AI8 analog input module and SoMachine Basic v1.6. I am trying to scale...
7,112
Hi, Is it possible to scale the 4 to 20mA output of a Vegaflex 63 TDR Level Senor mounted on an inclined horizontal cylindrical diesel tank with...
3,262
I have everything set up for vibration monitoring with the code in Controllogix 5000. The thing is that I am not able to read values SCADA in mm/s...
34
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
226
