Scary CPU 1515F behavier
Holmux
Oct 2013
Aalborg
279
Hi all
Was at a customer yesterday and had a look into the panel and found one of the CPU's in this mode.
The system was running fine, but no reaction to any of the buttons on the front of the CPU, I have a suspicion that this is just the front panel locking up.
Have anyone experienced the same behaviour?
The screen is entirely optional and unrelated to the run state of the CPU.
JRW has a good thought.
First thing I would for is remove the screen and reinstall. There is a slot at the top to pry with a small screwdriver.
There own technicians have replaced a Movimot motor and removed another one from the system, my guess is that its missing connection to this motor.
I will get online on the system later this week
Hello every one hope all are enjoying. I have an issue to connect omron NS10 HMI with CJ1M-CPU11 ETN plc I have made all required setting as...
30
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
58
I have a 90/30 CPU331. I am trying to upload the program out of the CPU and keep getting an error uploading the logic. Error 8262: Error...
125
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
328
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
203
