Scheduled Blocks in SoMachine Basic
QasimFSH
Apr 2018
Adelaide
142
Hi All,
I am trying to configure the scheduled function block in SoMachine Basic. It looks very simple, but just unable to get any results (I have set up SW114, unsure how to set S51). If anyone has some examples of this, kindly share. It will be really helpful.
Thanks.
If you use %SCH0
You need to enable %SW114:X0
%SW114:X0 means %SCH0
If you use %SCH1 you should enable %SW114:X1
If it helps anyone, this is a working code. Make sure to sync the RTC with PC`s clock, unless you want custom time input.
I think you should not short to drive coil %Q0.1.
Maybe you should use Schedule Block output to drive output coil
same as shown in attachment.
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
554
Hi, We have ControlLogix installed at my plant with Flex IOs communicating with controller through ControlNet module. Yesterday, while controller...
495
Hi I wanted a help from experts. I'm using S7 1200 PLC and KTP700 HMI in Tia V13 software, I tried to incorporate a scheduled task (in advance...
1,558
I'm going to through this feeler out here because there is a lot of knowledge here. I have a project that I'm working on that uses a L73...
2,226
Let me start by asking my question and then explaining it: In RSLogix 5000, are the logic and devices written within Tasks that reside in the...
5,821
