Schneider HMI Software
JohnB315
Oct 2018
Bally
Hi, I am doing a small project with a Schneider M221CE16T PLC using SoMachine Basic, I just happen to have a Magelis XBTGT5230 on the shelf which would really look the biz in this project. I'm just a bit unfamiliar with the Schneider ecosystem - are they compatible ?
Do I use Vijeo Designer or SoMachine to program the HMI, it seems like both can do it ? If so, which should I go for ?
I hope I have made this clear enough.
Thanks.
Hi.
the tm221 plc is programmed with somachine basic which cannot program the hmis. You are confusing somachine with somachine basic which are 2 different softwares. Somachine (for tm241 and tm251 plcs) can program the hmi but not somachine basic... You will need vijeo deisgner for this. And yes the hmi and plc will comm without issues
Hi.
Thanks for your response. That clears things up a good bit.
Has anyone found a Proface HMI that is compatible with Schneider M172 PLC?
390
Hi all, just wanna ask if anyone has used an M221 controller and successfully connected to AdvancedHMI
1,323
I have an M241 connected in Ethernet to a HMIS5T panel and I can't get them to communicate I'm using Machine Expert 1.2 On the controller the...
1,810
Hi, I have Schneider MTZ circuit breaker giving Energy value in int64 format (volts,amps etc are in FLOAT) What options do I have to display...
1,304
I've seen a few old threads on here that say there is no way to upload from one of these HMIs unless the developer took the step of downloading...
2,671
