Schneider HMISTU
Robert_M
Dec 2010
Wichita,KS
23
OK, I got my hands on a Schneider electric HMISTU655 to play with. I have created a project downloaded it to the HMI and the hmi reboots and then stops at the Initial start mode/ Language screen. I set the project to start the appliation with panel 1, but I never get there. Any ideas what I am doing wrong? Any and all help is appreciated.
thank you if you can help, I need to learn this for my next project.
I am not entirely sure what i have done, but I made it work. There are two places to to setup the first screen displayed. under Target properties, there is an "Initial screen" setting and a "Startup" setting. Seems kinda redundant don't it?
The initial screen is a physical page that you created where as the startup screen will be a picture or something that displays while run time is loading. Two different things
I see, thanks chud. I think my problem actually stemmed from not downloading to target correctly. My local Schneider rep showed me the error of my ways. Again thank you.
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
57
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
62
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
156
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
83
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
144
