Schneider M241 Modbus communication with multiple slaves
Yeah, first, I apologize for not mentioning this at the beginning.
My meters are connected through RS485-RS232-USB adapter to the PC.
I have a program for checking Modbus data called Modbus Poll and when I run it on the host, it works fine.
SoMachine is installed on a VM. Forget the SoMachine for now. I have installed the said ModbusPoll on the VM. When I try the exact same process of reading data through Modbus on my VM (as I did on the host), it simply is not working.
This leads me to believe that the problem is in the VM itself.
I am installing SoMachine now on the host itself, and I will try to run the logic then. Meanwhile, if anyone has any suggestions on how to make this serial-usb work on the VM, please let me know.
What VM software are you using ?
Where you connect usb to serial adapter when you have real PLC?
If you are running SoMachine simulator, then I think that it can't work, you need real M241 CPU for testing. Connection to it is maded which screw terminal or RJ45 not with USB
I have a RS485-RS232-USB adapter for simulation and connecting the slaves to PC. If I had a real PLC with me I would link the slaves to PLC via RS485 screw terminals an then plug the PLC to the computer with the miniUSB-USB cable for configuration.
Ok so apparently, it's not possible to simulate slave data readout without an actual PLC. I will need to do this on site then.
Thanks for the help guys, cheers!
196
Hello, Recently I was asked to analyze the logic of the air conditioning system in one of our departments. The PLC that controls this system is...
191
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
497
Hello everyone! I have a Schneider M241 as master of a CAN network with several encoders and whatnot, everything is working fairly well. Now...
1,742
I'm thinking of selecting the Schneider M241 PLC for a product line. Has anyone worked with this PLC before? Please share your likes/dislikes...
3,661
