Schneider-PM5320 Energy Meter Ethernet Communication With Rockwell PLC
prakasha
Dec 2022
Davangere, Karnataka, India
75
Hi All,
We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly instance Input size, Output size and Configuration size.. If anybody having idea on this Please drop a details here. if i get details that will be very helpful to complete my project. I wish to add as Ethernet generic Module
Thanks in advance
According to the PM5320 datasheet (https://www.se.com/au/en/product/download-pdf/METSEPM5320), that meter appears to only support Modbus/TCP and BACnet/IP protocols, not EtherNet/IP (which is why you won't be able to find Assembly details or use the Generic Ethernet Module).
You will need to either configure the Rockwell PLC to communicate Modbus/TCP (https://www.rockwellautomation.com/...d=modbus%20tcp%20client;activeTab=Sample_Code) or buy a gateway that can convert between EtherNet/IP and Modbus/TCP (or BACnet/IP).
Thank you for the reply..
Will you suggest me any latest meter which supports Ethernet with assembly instance details. Preferably I am looking for Siemens and Schneider meters.. I am greatful if I get right one to use.
Thanks in advanc
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
45
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
158
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
88
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
101
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
199
