SCL Postive Edge detection in Dword
MOeZ
Nov 2009
singapore
101
Dear Expert,
SCL Newbie question :oops:, i want to set POS_EDGE Detection output if any of bits changes in DWORD ? i been thinking and still not have correct answer yet.
Currently, i called "POSTIVE_EDGE" Detect Function block 32 times in STAT area of Main FB and check couples of bool one by one and is worked. But i wanted to improve performance in this FB and Hope somebody can help me with better
way of SCL? Thanks in adv. :oops:
Dear Expert,
Hi
I can give you an idea, the implementation of SCL it gets easier.
consider using the famous XOR, and here is the XOR function.
at the beginning and at the first execution, you double your word "EDGE" initializes a word "MD0" for example 0.puis you enter a boucle.Si MD0 XOR front is equal to 0, otherwise you a front and you will have the same posistion. 1: bit 1, 3: two front in the bit 1 and 2 .....
// the bits in oneshotword will be oneshots of the bits in sourceword formatted as WORD or DWORD
"oneshotword" := "sourceword" AND NOT "memword" ;
"memword" := "sourceword" ;
edit:
(deleted .. I made the mistake thinking that logical word operations have to be made on INTs or DINTs).
Many Thanks Jesper and Kour! will try it out Jesper Method (y) and Still have no idea yet Kour's Idea to use Famous XOR! :unsure:
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
98
Hi, I have an intermediate-advance knowledge of programming with TIA Porta in Ladder, would you recommend me to start learning SCL for it to...
575
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
349
Hi everyone, I am new to this amazing world of PLC, well... I mean, in practice, since I already knew electronics, programming languages, IT, and...
663
Hi all, This is my first post; I am new to PLC Controls stuff and English is not my native language, so I apologize in advance if something is...
516
