scratchpad text on PV300
RDP
Jan 2005
Ontario
Is there a way to display a variable in the text that pops up when you use the numeric sratchpad entry? when the scratchpad pops up, it overlaps the entire screen so data that is under cant be seen. Or is there a way to format the size of the scratchpad? panelview is 2711-K3A17L1 FW4.41
THANKS
My version of Panelbuilder shows only two choices for the text area - 'show current text' and 'masked'. The 'masked' is probably only used for a 'password' type entry so that's probably not what you want. Can you do anything by manipulating the 'current text'?
I have only found in PB32 v3.81 where under application settings, External Fonts the change for numeric scratchpad customization, and I can type in text, but if I try to put in a variable it just shows the formatting for the variable and the tag name on the screen as the prompt.
thanks
This is might be a long shot, but what the heck.... Does anyone know if it is possible to modify the Numeric Input Scratchpad font size and color...
2,669
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
283
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
120
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
130
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
416
