Seimens 505-1102 I/O problem
Rory Oliver
Feb 2003
Seimens 505-1102 doesn't seem to be communicating with my I/O cards I make input changes but they dont show up on the ladder in run mode it,s like information is static
Rory
What I know about the Siemens 505 range you could write on the back of a postage stamp in block capitals, but I will try to help you out here.
Are the I/O's in question local or remote? If they are local, are there dip switchs that have to be set? if so are they correct?
Are your 'input changes' showing up on the input card, in other words is the card wired correctly?
If you can answer these questions, then post the answers back here and I will have another try, or hopefully maybe one of the other regulars will chip in with some advice.
I think that you need to check that you have addressed the inputs correctly.
Hope this in some way goes to help you
Paul
Are you progamming "On Line" or "Off Line"? It sounds like you are programming off line and then not down loading the changes. Most people program on line in the "program" mode.
opening up a copy of my HMI program I can go to where the passwords are created but they are all asterisks. How can I view what is there? I see...
1,104
I have installed ver 16 of tia portal and I am running in the 21 days grace period. My question is this, is it fully functional during that 21...
3,087
Hi; In our corrugator plant, there are one Corrugator and five Flexo graphic printing machines. One of them is a BOBST brand French made...
1,923
We have these in our shuttles. The IP Address is stored on the SD card for the unit. We had a card go bad and I am trying to copy another card...
1,168
Good morning, experts! I have a Siemens PLC and IO that I need to cross to Rockwell, and I have zero experience with the Siemens line of products...
1,557
