Selection of frequency module
jcp
Feb 2010
Multan
369
Hi;
I am using GE Fanuc 90-30 series with CPU 352. I want to know which module serial number is compatible with this sytem which capable to read the sinewave frequency means connect directly to the magnetic pickup to measure the shaft speed.
The resistance of the magnetic pickup is 198 to 210 ohm and gives me 12000 hz at 100% speed with max 20 Volt amplitude.
Before that i used the IC693APU300 high speed counter module.
For that i wire up the magnetic pickup as under
magpickups wire comes into FTV which gives me pulses according to the input and i used APU300 as a counter type A.
If a module which support directly magnetic pick up i think its better to control the speed.
Regards
Hi;
Respected friends;
I attached a detail images of configration and wiring diagram also attached a documentation of FTV which i used.
I need help to set the configration of APU 300. Is it correct or not.
The input frequency is 12000 Hz @ 20 v AC rms. Feed into FTV which generates the pulses. And i see on oscillscope it is square wave almost with 10 volt amplitude P-P.
According to that data i set the APU300 configarttion.
1.All the filters set at hi frequency.
2.OSC input at OFF (what effect if i ON it)
3.OSC. Divider at 660 (what effect if i changed it)
4.Count mode=contineous
5.count dir =up
6.Time base=1000 (if i changed it what effect)
7.ON and OFF preset is -00001 and -000002 (what effect)
8. PLD value is off
I ask this in detail becuase
the shaft speed is the major parameter of controlling the speed of gas turbine. It works well but at specific point when frequency between 10139 to 10485 some overshoot occur i think some resonance effect occur. To avoid this may be some setting in APU change and it fix it. I am stuck here please help me.
Below and above that frequencies machine behave very well.
Regards
  • WIRING CONFIGRATION OF SPEED INPUT.doc
  • FTV 1393.00_e.pdf
Since it's working I'd say your configuration is correct.
The OSC is an internal frequency signal generated by the module. It is an alternative to a pulse train coming from an external source. The OSC frequency is fixed, but the OSC divider can be used to change the frequency. There is nothing in the internal oscillator signal that can help you with your resonance problem.
The time base is what the module uses to calculate frequency. The value is in units of milliseconds, so 1000 equals one second. The module counts att pulses in a one second period and reports that to the PLC in the counts per timebase register. The effect if you change it will be to change the reported frequency you're currently using. If you change it to 500, you will see the counts per timebase value cut in half for any given speed. since you're using that as your PV in the PID function, you'll be disappointed with the result.
ON and OFF presets control the action of the module's transistor outputs. You're not using them, so changing either of those parameters won't have any effect.
All of the above is described in greater detail in the manual.
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
168
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
117
Dear Members; We are going to design a Simplex Control System With Following: 1. 24 Digital Inputs (SIL 2) 2. 24 Digital Outputs (SIL 2) 3. 4...
1,148
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
425
Hello, Not able to find Modicon DO modules BMXDDO3202 in EcoStructure Control expert V15 catalogue. But i can find only MBXDDO3202K. Can you...
495
