Send Tag Status in Email RSL5000
fdiaz
Sep 2015
California
Hello Everyone,
RSLogix 5000 v16
Ab1756-L61 with ENBT/A
I am wanting to send the accumulated number of a counter, or a tag that is the result of a math instruction, embedded with some text to my email.
I have been able to successfully send a string tag by following the guide in Ethernet/IP Network Config Manual. I have searched through the forums and the majority point towards either this manual or Technotes which I do not have.. I'm a project engineer intern so I have only been working with ladder logic for less than a year.
Is this possible? If so would anyone be willing to point me in the right direction? Thank you!
Check out the DTOS (DINT to STRING) or RTOS (REAL to STRING) instructions. If you already know how to send a string, making your value into one should be the only missing link
Within RSLogix 5000 Open 'Help' - 'Instruction Help'
Read each instruction in the 'ASCII Conversion' and the 'ASCII String' sections. That should give you some ideas about creating the sections of the string for the email and connecting them together.
Thank you gentlemen. It was so simple now that you helped.
Not sure if it was the best way but it is working.
I used DTOS to get a string type, then MOV that to the correct array position in my EmailString tag.
Working on an upgrade project, going to replace an L63 revision 17 with an L74 revision 30. In newer L74, MSGs with large tags as source/target...
779
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
452
can the slc500 5/05 send a email and text over Ethernet ?
195
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
202
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
203
