Sending Emails from PLC
Jun 2023
Ohio
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately to send emails? are there basic mail relay servers online I could use to achieve this?
Check out previous thread
check out this thread from a while ago.
https://www.plctalk.net/qanda/showthread.php?t=115980
I have never sent emails from a PLC directly and not sure of any that can do that. Perhaps there are some specialty models.
Typically I log events in a SCADA system or use a Alarm Manager (OAS, Wonderware, Factory Talk, ect.) Then use those services email servers to send message. Most will allow you to send a tag value, so you could populate an alarm tag with some text. I have also done some IF statements in the SCADA systems so I can use a DINT tag that correlates to some string of text.
IE: IF Tag == 1 THEN "system good"
ELSEIF Tag == 2 THEN "System has boo-boo"
Hope this helps point you in the right direction to solve your issue! GL
What PLC and email service are you using?
I got emails working from an S7 via gmail a couple years ago. It's definitely possible.
I have a 1734 AENT and I'm trying to send it to a mail relay server first, then send it to individual emails accounts from the server. The main thing I am struggling with is figuring out how to create a mail relay server so I can add it as a module on studio 5000
I don't think it would be a module in the PLC rack. It would be a service running on a computer. It could be local on site, or in the cloud.
All ControlLogix/CompactLogix can send emails. You may need a newer Ethernet card for ControlLogix like a 1756-EN2Tx.
For Compact you will need to check your model, and may need to send the messages to a newer Ethernet card in a different rack.
Rockwell has great sample code for it.
Need help setting up the MicroLogix 1500 to send emails.Also need to know how store a string in a data file.
2,272
I've been trying to get this Ethernet module configured to send emails to our relay server but cannot get it to work. the EN2T is running...
1,765
Hi Everyone, I'm using a small program to generate emails when certain conditions are met like when a counter exceeds a value. I was hoping that...
2,004
So here's the deal. I'm fairly new to red lion HMI's, and this job, but have picked up the programming enough so far to build screens and make the...
3,748
Hello everyone, I am trying to send an email with a Compact Logix L33ER. I used the example provided on the rockwell website, but it did not...
2,988
