Sendkeys utility
cjd1965
Apr 2007
UK
1,659
Hi
I have approx 250 rungs of very similar code i need to type. It is a cheap IDEC plc.
I have an excel table of the bits i need to type and was trying to use send keys to type my code but it did not work...any ideas?
The App opens but the keypress A does not work... If i then press A on the keyboard it works as expected.
I am looking for a method of sending string data/ enter keys/ etc to the programming app.
Code:
'excel macro
Sub IDEC()
AppActivate ("WindLdr - [0 Subroutine]") 'open sub 0 , alarms
Application.Wait (Now + TimeValue("00:00:10")) 'wait 10 secs
Application.SendKeys "A", True  'send A to activate XIO contact
End Sub
Hi I found a tool called autohotkey.
unfortunately the idec software doesnt seem to like excel\sendkeys or autohotkeys so the 'sendkeys' doesnt work but a keypress does... and sendkeys/autohot keys works fine in notepad etc
Cheers
Have you looked into the software object model? I'm unfamiliar with this product but some packages give you the ability to use the object model and VB (etc.) to handle things like database and code manipulation.
Good luck,
(8{)} :) .)
(Yosi)
Not What I'm talking about...
If you program in VB (or similar) you may have the option of using the same functions the PLC software itself uses in order to add rungs, etc... To find out if you can do this you'd look under Resources in VB for IDEC objects. From there on out it all depends on what IDEC supports.
If you don't program VB (or similar), never mind.
Good Luck,
(8{)} :) .)
(Yosi)
Does the IDEC software have a "save as" to a text format?
Or Export routine function
Have you tried using AutoHotkeys to save the keystrokes first then modify the macro created?
I used Sendkeys for years then microsoft broke it
I have found auto hot keys a good replacement
I am trying to send the 'ENTER' key press as a command behind a button in RSView32. Existing code: SendKeys "{ENTER}" I have a string input...
2,403
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
618
Hello all, been a while. I am unable to open Transfer Utility as a stand alone or threw FT View Studio. I have reinstalled FT View Studio, Linx...
1,460
Hello, I am stumped with logging into the remote directory located on a server setup with a Network Distributed Application. I can't seem to get...
1,139
I have FTView Version 11 running on Windows 10 and I can't upload or download to any Panelview. I get the "Source selected is not a valid device"...
3,871
