I am hopeful that some one may be able to help with this application. I have an automated dial table which uses 2 Corona generators to treat injection molded parts before they are printed. The corona is created in by shorting a high voltage electrical charge about 2 inches away from the face of the part. Compressed air is used to dissapate the corona onto the part. The parts are then printed, and the corona allows the ink to ahere to the part.
Last week I was notified that some of the parts were not being treated with the corona. Some parts were randomly tested and it was found that the ink would rub off. I noticed that there were no alarm outputs or other I/O on the generator that could be interfaced with the PLC. I contacted the manufacturer of the units, and he suggested installing a current sensing relay on the 120VAC feed to each of these units, and monitoring this with the PLC. This seemed like a good solution, so I went ahead and wired in two current sensing relays, and interfaced them with the PLC. In the event the Corona generator was triggered, but I did not see the output from the current sensing relay, I take the machine out of Auto, and sound an alarm. The operators have been instructed to remove all product from the table, and reject it before proceeding.
I tested this logic several times, and everything worked great. On our next trial we experienced one alarm, and the operators followed the procedure to reject the parts. However we still had parts that did not get the Corona treatment. Again I contacted the manufacturer, and he explained that it could be possible, that even though the current relay was activated, corona was not generated at the tip of the machine. Keep in mind that the Corona generators mounted on this are very old.
We are now trying to find some method to detect Corona directly at the tip. I have searched the web for some kind of sensor, but have not been able to find something.
Any ideas would be greatly appreciated.
BigAl
BigAl
