Sensing rise / fall changes in test setup
speechsupply
Oct 2016
Jylland
The sensor has a 4-20 mA output.
In order to get an analog 4-20 mA value into a PC, there are many ways.
If this is a permanent industrial installation, I would suggest to use a PLC as the datalogger, and then connect the PC to the PLC to fetch the data. Some small PLCs even have a webbrowser interface so you can retrieve the data without having to make a special PC program to connect to the PLC.
One such small PLC is Siemens S7-1200 which is reasonably inexpensive.
Okay thanks!
Think I'm looking at some expansion modules then - need to make atleast 3 setups. So 9 analog signals.
Can you recommend any litterature on getting started with PLC ?
Everyone has their favorite plc to use.
I suggest that you look in your area and find local plc distributors and see what they have to offer. Ask around and see what their customer support is like. Great or not so good. Then make your selection.
that would be my first step.
james
Looking for some ideas on sensing contact between 2 metal parts. The application is a part gauge fixture. The gauge and part are both conductive...
3,134
Hello everyone, What's the difference between nominal sensing distance and maximum sensing distance in a diffuse photoelectric sensor ? in...
1,130
Hi all, Looking for a temperature sensing solution for determining ambient temperature in the frigid Canadian winters. Discrete outputs are fine...
1,509
I did an application 2 years ago where I need to know level in a pressurized tank and the system had an existing sight-glass that I took advantage...
2,028
Hello! I am looking for some help to know if I have the correct setup to monitor the speed of a motor running. The motor RRM is 3490 and the...
21
3,788
